Adding a note to an existing entry
981 1
Kelsey_Begin
Hi all! I’m trying to add the functionality to my airtable wherein a viewer/editor can add a note to an existing entry without having to type over the entry. Ideally, this would function like a digital sticky note, so I can view the comment, but it doesn’t impact the structure of the airtable itself. Does anyone know if that’s possible?
Thanks in advance!
18 - Pluto
18 - Pluto
Welcome to the community, @Kelsey_Begin! :grinning_face_with_big_eyes: Are you familiar with the “Activity” feature on records? Users with proper permissions can add comments at the record level. More about this can be seen here:
18 - Pluto
18 - Pluto
