I’m trying to ingest a new user registration (password’s being handled separately).
I want to make sure that the new registration does not use an email address already in the DB (prevent duplicate accounts–ideally even if they’re using “+variable” in something like a gmail address).
I’m currently using automations, but I can’t seem to get around the “Find Records Action 0 results stops the automation” flow. I actually want to update the record AFTER a Find Records determines there aren’t any duplicates.
I’m not using scripting – “Plus” account level and coming in from the #nocode crowd.
Here’s the where I am thus far:
Automation 1:
WHEN: a record is created in Ingest Users Table
ACTIONS:
Find Records in Active Users Table where email = [new record email]
Update Record (that was created) → set Duplicate = true[I would IDEALLY be able to handle Find Records = 0 results with an Update Records → set Unique = true, then have a When Record Enters View that copies the Ingest User record to the Active Users Table.
Automation 2:
WHEN: a record enters a view (Ingest Users.Unique = true)
ACTIONS:
Create Record in Active Users Table
Update Record (that entered view) in Ingest Users Table → set Processed = true
Find Records in Active Users Table where Created From = [record that entered view]
Gmail send welcome email[again, IDEALLY handle Find Records in Active Users Table = 0 results with error logging/graceful failure involving logging and emails]
Notes:
- I have a number of different jukes using multiple different table views qualified by different checkbox variables (and a few formulas). Those fail because somehow the when enters view triggers can fire WHILE another automation is running. So if I, say, mark a record as Unique = true, then check for duplicates, then update → Duplicate = true AND Unique = false, the record already popped into the IF Unique = true view and triggered the next automation.
- I have read support/Find records automation action and understand that what would be my ideal solution is somehow outside of current automation functionality
- I have read Finding Record Automation - What if Not Found? and will own up to the fact that it is probably similar
- I will be cranky if a script is the only solution. But I am tired enough that if someone hit me with a rough script solution I’d probably just cry into my
and upgrade to put it into production.
I was really excited to build my #nocode app out of Airtable. But this has really hit my morale (and momentum)!
Thank you for any help, suggestions, or insights you might be able to provide.
