Autonumber script problem
Topic Labels: Automations
816 2
Melissa1
I use an easy airtable script for the autonumber.
The problem is that it works for one table but not for a second or third table. Do you have an idea ? Is there an error? I keep checking but fields and everything seems correct to me.
Thank you for your answer
Mélissa
Capture d’écran 2022-05-19 à 11.29.10
Capture d’écran 2022-05-19 à 11.29.35
Capture d’écran 2022-05-19 à 11.30.31
Capture d’écran 2022-05-19 à 11.30.46
18 - Pluto
18 - Pluto
Looks like you have a typo in the table name when you set the input variable. Should there be a space after the emoji?
18 - Pluto
18 - Pluto
You’re right @kuovonne ! there was a space after the emoji.
Thank you so much :star_struck:
Have a nice day
Mélissa
