Bit.ly Link Shortener Script for automation
Topic Labels: Automations
1304 0
btg202
Hopefully useful for someone. If you set a variable called ‘Shorten’, then you can use this script to pull the URL and turn it into a bit.ly link which you can then use to automate something else! Feedback always welcome.
let inputConfig = input.config();
let response = await fetch('https://api-ssl.bitly.com/v4/shorten', {
    method: 'POST',
    headers: {
        'Authorization': 'API CODE FROM BITLY GOES HERE',
        'Content-Type': 'application/json'
    body: JSON.stringify({ "long_url": inputConfig.Shorten, "domain": "bit.ly", "group_guid": "THIS CAN BE FOUND IN THE URL OF YOUR BITLY ACCOUNT" })
let bitly = await response.json()
output.set("bitly", bitly)
0 Replies 0
