Grouping same names will leave out records
Topic Labels: Base design
1759 3
Eliza_Piotrowsk
Hello, I am a new user- I created an Airtable base that is updated via Zapier from a Google sheet. The records seem to be populating from the Google sheet correctly, but when I try to Group by Client name, not all the records are grouped. I will have some records with the same name in it’s own group. This has happened a number of times so manually dragging those records to the other grouped records of the same Client name has become cumbersome.
Has anyone else experienced this and know of a fix or what I may possibly be doing wrong?
Thanks in advance for any help on this topic.
18 - Pluto
18 - Pluto
Welcome to the community, @Eliza_Piotrowski!
I would check for extra spaces (or invisible characters) at the end of the client name, or the beginning of the client name, or somewhere within the client name.
3 Replies 3
18 - Pluto
18 - Pluto
Thank you ScottWorld, that was it! I went back into the Google sheet I was pulling the data from, highlighted the column that contained the data, and used the Trim whitespace option in Data.
That’s great to hear! You’re welcome! :slightly_smiling_face:
