Jun 17, 2021 06:20 AM
Hey guys I know how to add the template into my workspace but is it possible to add this data within a base as well? (this base has already been created).
For example, what I am doing right now is trying to move a template called: team workload planner into the one my current bases for the team without removing any info in our current base. Is this possible? Thanks so much :slightly_smiling_face:
Jun 17, 2021 06:57 AM
You cannot import a template into an existing base in one step, although that is a great idea.
You can use the template to create a new base, and then manually copy the tables over one by one. You cannot copy the configuration of a linked record field or a calculated field (formula/lookup/rollup/count). However, you can copy the field names and the contents. The easiest way is to first make it a synced table, then unsync it. Finally, reconfigure linked record and calculated fields by manually copying the configuration.
Jun 17, 2021 07:16 AM
:white_check_mark: Thanks so much for your help with this, makes total sense! Appreciate it
