- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
Jan 28, 2020 01:54 PM
I’m using two tables in the same base connected by a zap to create an automatic updates log (the second table) of repeating tasks in the first table. It’s a Health & Safety maintenance system.
Table one lists all the regular things that need doing - first aid box refresh, car checks etc. When a check is completed the checker updates this table and it automatically updates a iCal so the next time check is in the right persons calendar. The table has a “last update field” which I use to create a filtered view that only has checks updated today in it.
I use a zap to spot the updated view record and create a new record in the second table - the log of events. This is totally auto-generated as an audit trail. It lists the check completed and other details about it. This is the table used to report H&S activities.
But it’s a bit complex - is there a better way?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jan 28, 2020 10:51 PM
Hello Hazel,
I can think of 2 options:
- Instead of updating in the task direct, create a second table with activities against a task. This way your changes dont impact the task directly and the activities table itself can become your audit trail. The downside this can be edited so not so secure.
- With integromat you can write filters for the API calls so you dont need to build the view - this keeps your airtable setup clean and makes it more robust. You can also run it more often than once a day.
Let me know if you need me to expand on any of these.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Jan 29, 2020 10:42 AM
Thanks Cor,
Security is an issue here do I’ll investigate integromat. :thinking: :grinning:
