Lead Routing Possible?
Topic Labels: Base design
1044 1
Push_Texas_FFS
Hello everyone i am new to air table and i would like to know what is the best possible way to integrate lead routing into the system!
Zach_Manzi
Hi @Push_Texas_FFS,
Zach from Airtable here :wave:
Welcome to Airtable! We’re happy to have you. I’d recommend takings a look at Airtable’s integrations––you can use Zapier, Workato, Integromat, or Automate.io to connect Airtable with over 1000 websites and apps. There may be an option here that works for you!
Zach_Manzi
Hi @Push_Texas_FFS,
