Modifying tables and views using a script
504 2
Partnerships_Co
Hi everyone, I want to trigger a script that will create a new section. inside the section, it will create views and filter them. I couldn’t find a way to achieve this. I searched in the community and found that this had been requested before. this s would really be beneficial to have since it will automate processes.
Also, another thing is having the ability to duplicate a section with all the views in it. instead of duplicating all the views in a section, move them one by one.
Is there any way for these features to be applied! or maybe it is applied already but I haven’t found a way to use them yet.
Thank you
Currently Scripting cannot create views and cannot create view sections.
Hi @kuovonne,
Thank you for your reply.
I understand, but is there an easy way to achieve this!
