Aug 29, 2019 08:36 AM
This is my first time using Airtable, started just today.
I’ve been trying to find an answer but have so far been unsuccessful.
What I mean is - I have 5 topics (as shown below), a user can navigate to the next section only if s/he completes the previous section/tab. Each section/tab has a set of different types of questions, along with a next/previous buttons.
Thank you so much! :slightly_smiling_face:
Solved! Go to Solution.
Aug 29, 2019 10:10 AM
No - but you can link from one completed form to another (requires a paid AT plan), so you can get a multi-step process this way:
5 linked forms imply 5 AT tables, so the trick here is linking the different submissions to a single entity. This process is easier if you use a 3rd party form solution - Typeform or Jotform (with Zapier in the middle). Have a read of these posts covering similar topics:
Unfortunately not (with AT forms, at least), other show/hide or vertical order.
JB
JB
Aug 29, 2019 06:34 PM
Try Jot Forms to add flexibility and logic - during data entry and data dissemination to multiple tables/bases etc.
