Nested IF AND statement with two different calculatoins
8830 7
Kristen_Gerzin
I need to create a nested IF(AND statement for my commission sheets.
Logical Argument 1: If the Set By field has a value in it AND
Logical Argument 2: If the Month field is January, February, March or April
The result would be:
  1. Calculate the formula Profit/2 multiplied by .125, otherwise blank.
I also need in the same column:
Logical Argument 2: If the Month field is May, June, July, August, September, October, November, December
  1. Calculate the formula Profit multiplied by .0625 ., otherwise blank.
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
This assumes, based on the way you worded your request, that the Month field produces a string with the month name. If this is not the case (ie, it returns a number or an actual date data-type, the OR() statements may need to edited to reflect the appropriate data type):
   AND(
      {Set By},
      OR(
         Month = "January",
         Month = "February",
         Month = "March",
         Month = "April"
   (Profit / 2) * 0.125,
      AND(
         {Set By},
         OR(
            Month = "May",
            Month = "June",
            Month = "July",
            Month = "August",
            Month = "September",
            Month = "October",
            Month = "November",
            Month = "December"
      Profit * 0.0625
7 Replies 7
Jeremy_Oglesby
14 - Jupiter
14 - Jupiter
   AND(
      {Set By},
      OR(
         Month = "January",
         Month = "February",
         Month = "March",
         Month = "April"
      AND(
         {Set By},
         OR(
            Month = "May",
            Month = "June",
            Month = "July",
            Month = "August",
            Month = "October",
            Month = "November",
            Month = "December"
      Profit * 0.0625
Oh my lanta. You are a life saver. Thank you SO very much.
Not sure how my eye caught this so quickly, but the calculation in Jeremy’s solution has the operators reversed:
Based on your description, I believe it should be:
Thanks, @Justin_Barrett. Fixed it.
Of course,
is the same as
Profit * 0.0625
which removes the need for the formula :slightly_smiling_face:
(@Kristen_Gerzin - maybe one of the blocks of months needs a different commission calculation?)
JB
Kristen_Gerzin
You make a completely valid point. I will need to revisit this with my sales team, as they were originally paying the 12.5% out of their commission, whereas now it should be 0.625% out of their commission.
Not quite. 0.125 is the same as 12.5%. 0.0625 is 6.25%, not 0.625%
