Problem with the integration of typeform and airtable using automate.io
Topic Labels: Integrations
1765 2
faiberts
Hi friends I recently tried to use automate.io to integrate typeform and airtable, the integration I used for that was the following:
notaio
where I only want each record of typeform to be a record within a specific table. which I attach its configuration; where I send from a form of 5 simple records to 5 records of the same type of data.
notaio1
The detail is that after registering some typeform, then when checking the table gives me the following error, which is the identified of the typeform form, I do not understand why gives that error placing a record in that table and then in another record the capture of that form.
airtable
If anyone knows how to remove that error, I would appreciate it.
Jaynish_Sharma
Hi Faiberts,
Can you please reach out to us by using the chat bubble icon that appears on the bottom of the screen and we can investigate this further?
We’ll be happy to assist you and get things working for you.
SLT_UXd
Hi @faiberts - Did you ever get this sorted out?
