Script: Meta Definition
1922 0
openside
10 - Mercury
10 - Mercury
Something very often requested is the ability to extract the meta information of a base/table to be used for external use.
Now, with the new scripting block, that information can be extracted and shared outside.
Simply copy this code into a scripting block and run it. If you wish to publish to a 3rd party endpoint, simply modify the codebase. Full documentation provided inside the code.
0 Replies 0
