Shared view links expire after time frame
Topic Labels: Views
1321 1
Michael_Kruse
Is it possible to have a shared view link expire or become disabled after a certain time frame?
I’d like to be able to automatically expire a link after a week or on a certain date, so I don’t have this link floating out there after the event date or whatever. For example, the form view should expire after the registration deadline. Is this possible?
Unfortunately not, but you can disable the link manually.
