Shortcut for expanded view
741 1
Zo_Benbrahim
Is there a keyboard shortcut for jumping to the next cell in expanded view? I know that I’m able to move to the next/previous record with ⌘ SHIFT . or ⌘ SHIFT , but I would like to move to the next paragraph within the same record and I don’t see a shortcut for it. It is really hindering my productivity as I hate having to reach for my mouse unless I have to.
The Tab key advances to the next field when in expanded view. Shift+Tab will move to the previous field.
