Slack Notifications per Field instead of per Base
Topic Labels: Integrations
1404 1
Monica_Crockett
does anyone know how to get notifications to someone only if a specific field in a base is changed instead of if any field in a base is changed? I have a base that pertains to all my employees but they do not all need to be notified when some fields are changed in that base. I do need them to be notified on the fields that pertain t their specific job duties tho.
Any help in this would be greatly appreciated. We are currently using the free version and if we can get this one specific part down we are not against paying for the site completely or if the paid version is how we get to enable this function.
openside
10 - Mercury
10 - Mercury
Hi @Monica_Crockett, you could set up some notification in Zapier or Integromat to handle that use case.
