[Solved] Script Settings: CreateRecordAsync
1749 2
Chris_Guthrie
7 - App Architect
7 - App Architect
I’m having some trouble using a Script Setting input field when building a new record using CreateRecordAsync. Any help would be appreciated! Thanks!
I keep getting errors like this
Field ‘orderEvents’ does not exist in table ‘Inventory & Order Events’
at main on line 318
Here is my setup
const config = input.config({
title: 'Replenish Script',
description: 'This utility/script acts like a form for choose information about the coming replenishment',
items: [
    input.config.table('eventsTable', {
        label: 'Inventory & Order Events',
        description: 'Choose Inventory & Order Events Table'
    input.config.table('locationsTable', {
        label: 'Locations Table',
        description: 'Choose the Contacts and Vendors table'
    input.config.table('measurementsTable', {
        label: 'Measurments Table',
        description: 'Choose the measurements table'
    input.config.table('productsTable', {
        label: 'Products Table',
        description: 'Choose the products table'
    input.config.table('ordersTable', {
        label: 'Ordres Table',
        description: 'Choose the Table with our Order Groups'
    input.config.field('panStarInventoryField', {
        label: 'Pan Star Inventory Field',
        parentTable: 'ordersTable'
    input.config.field('rppPreppedInventoryField', {
        label: 'RPP PRepped Inventory Field',
    input.config.field('regionalExpressInventoryField', {
        label: 'Regional Express Inventory Field',
    input.config.field('gillInventoryField', {
        label: '616 Gill Ave Inventory Field',
    input.config.field('totalInventoryField', {
        label: 'Units @ 3PL Inventory Field',
    input.config.field('cartonInfo', {
        label: 'Carton Info Field',
        parentTable: 'eventsTable'
    input.config.field('locationVendor', {
        label: 'Location/Vendor Field',
    input.config.field('transactionQty', {
        label: 'Transaction Qty Field',
    input.config.field('orderGroupSummary', {
        label: 'Order Group Summary Field',
    input.config.field('productOrderGroupSummarytable', {
        label: 'Product Field',
    input.config.field('orderEvents', {
        label: 'Events Field',
//set models
const cartonInfo = config.cartonInfo;
const locationVendor = config.locationVendor;
const transactionQty = config.transactionQty;
const orderGroupSummary = config.orderGroupSummary;
const productOrderGroupSummarytable = config.productOrderGroupSummarytable;
const orderEvents = config.orderEvents;
if (shouldContinue == "yes") {
let recordID = await config.eventsTable.createRecordAsync(
        orderEvents : { name: destination },
        "Date": new Date(),
        productOrderGroupSummarytable: { id: product },
        orderGroupSummary: { id: selectedOrder },
        transactionQty: (parseInt(unitsToDeduct)) * -1,
        locationVendor: { id: selectedVendor },
        cartonInfo: { id: selectedCarton }
18 - Pluto
18 - Pluto
You need to put square brackets around the variable name when using a variable as an object key. You will need to do this for all of the object keys, not just the first one.
[orderEvents] : { name: destination },
18 - Pluto
18 - Pluto
Chris_Guthrie
7 - App Architect
7 - App Architect
That was it. Thanks!
