Sort selected range of records in grid view
Topic Labels: Views
667 2
Gareth
Is it possible to select a range of records in grid view using the checkboxes and apply a sort to just that range?
Kamille_Parks
16 - Uranus
16 - Uranus
No, but that would be neat! The sort option at the top will always sort every record in that view, not just selected records.
Kamille_Parks
16 - Uranus
16 - Uranus
@Kamille_Parks that’s what I thought was the case; thanks for taking the time to confirm it.
