Syncing two tables without loosing data
Topic Labels: Sync
592 1
Orkhan_K
Hi!
I have two bases in the same workspace and I am trying to synch one view to another base. On top of it, I use the synced view as a linked field. However, as soon as I use filtering on the view (the one I use to sync), I loose all data on another table. Is there any way to avoid it?
Don’t filter the view that you’re syncing.
Create another view if you want to filter.
