Non-developer type here! My team is using Airtable as a task management tool Each week we run a report, which includes a long text field (“Details Field”) with details on the work performed on a specific task during that week. To retain a record of the content that’s appeared in the Details Field, I wonder if it would be possible to write a script that would copy and clear the values of the Details Field and cumulatively add them to a field (“History Field”). The History Field would then eventually contain a list of all the updates that’s been put into the Details Field over time (and ideally with date stamps to next to the text that was copied at a given time).
// set the table
let notesTbl = base.getTable("Notes");
// get the table records
let notes = await notesTbl.selectRecordsAsync();
// loop through the records
for (let record of notes.records) {
// set variables to the record values
let notes = record.getCellValue("Notes");
let notesHistory = record.getCellValue("Notes History")
// set variable for today's date
let now = new Date().toLocaleDateString("en-GB");
// define the newNotes variable with starter text (includes the date)
let newNotes = "======= Copied " + now + " ======= ";
// only run on records which have notes
if (notes) {
output.text(`Copying notes for record ${record.name}`)
// build the newNotes value from the notes...
newNotes = newNotes + notes;
// ...and the notes history
newNotes = newNotes + notesHistory;
// update the notes history value and reset the notes value
notesTbl.updateRecordAsync(record, {
"Notes History": newNotes,
"Notes": ""
WARNING:
Quickly put together so please try this out on a copy of your base and check that it works for you before you put it into production!
It takes the text from the “Notes” field and prepends it to the “Notes History” field with a date stamp:
Yes, this is a good task for a script block and the general design is quite simple.
Read each record’s Details field
Append the content to the History field
Clear the content from the Details field
Rinse/repeat for all records
One issue - it would require a manual process so forgetting to run the script block would result in the weekly report containing two week’s worth of content.
The script would also need to format the concatenation perhaps with line breaks between each update for good historical reading enjoyment.
I believe you can make a quick template and put it on the Universe that takes the value from 2 cells and concatenate it into a 3rd cell, this will be very helpful to many people.
Something like
Bill
1235
Bill 1235
French
365
French 365
Jen
9685
Jen 9685
The reason for this would be so the 3rd field is a linked field instead of a formula.
Well, yes - this might be a useful template, but that’s not the requirement (as I perceived it). @JonathanBowen seems to have nailed it.
Sidebar
I’m not convinced Universe is where script block examples are best shared. Imagine if Duracell shipped you one triple-A battery in a giant box. I think this new feature has created an opportunity for a kinder, simpler approach where entire bases are not required to share such simple code fragments.
We recommend sharing on Universe in cases where the script relies on a specific base schema. This makes it easier for other users to see the script in context (and enables one-click install), without having to reverse engineer the relevant structure. For smaller code fragments that are more general purpose, feel free to share them as-is in code blocks on the community forum.
Yep - that makes sense. In my work, I tend to build things that intentionally avoid base dependencies, thus offering users far greater agility when applying the scripts to their own solutions.
I was wondering if this script can be used/modified for copying a list of multi select options from one field (filled in already) to another filled in multi select field.
// set the table
let table = base.getTable("Table 1");
let query = await table.selectRecordsAsync();
for (let record of query.records) {
// check that Multi-select 1 is not empty...
if (record.getCellValue("Multi-select 1")) {
output.text(`Copying the multi-select values for record ${record.name}`)
// now update Multi-select 2 with the array of ids in Mulit-select 1
let msCopy = await table.updateRecordAsync(record, {
"Multi-select 2": record.getCellValue("Multi-select 1")
In some ways, it is a bit simpler than the other script as we don’t need to take account of values in the 2nd multi-select (I assume), just copy MS1 to MS2:
If you wanted the script to be additive rather than replacing, then it would be a bit more involved as you would need to form an array of IDs from MS2, then add the IDs from MS1 to it, before saving this array to back MS2.
One thing to be aware of is that the script cannot create new multi-select values in MS2, so if you have a record in MS1 with a value of “Five” and this doesn’t exist as an option in MS2, then you will get an error. Also, nothing to stop the second multi-select being in a different table, just need to set the second table and reference this in the update.
Hi @M_k, so the only things you should need to change are the table name (my script refers to “Table 1”) and the two multi-select field names (where I have “Multi-select 1” and “Multi-select 2”). Change these values to match your base. In fact, maybe make a copy of your base first, edit the values noted above to match your base, then try it out. Assuming all is well, then move it over to your original base (making sure the table and field names are still good).
Beyond that, there should be nothing. The script doesn’t care what the multi-select values are as long as they are the same in both MS fields.
@JonathanBowen, As a follow up question, is it possible to set the colors for the multi-select options as well? It seems looking through the different field options for multi-select it should be possible, and if I had a column/array of the color options that it looked to for the choices.
These are great examples, I’m seeking to use the script block to populate image url’s into image fields. I have an image url field and have been attempting to modify your code to copy / past to the image field, but it needs an array.
“Error: Can’t set cell values: invalid cell value for field ‘Image’.
Cell value has invalid format: must be an array.
Attachment field value must be an array of objects. New attachments must have property ‘url’ and optional ‘filename’. Existing attachments must be passed back unmodified.”
Do you have any ideas as to how to go about using the script block for image updating in this manner?
@JonathanBowen thanks for the multi-select script example. I have a similar challenge, but would like to copy comma separated values from one field to another which is a linked value field (so the unlinked values become linked values). Any ideas?
Hi @Sabostar - If I understand your question correctly, using a script you want to copy a value in one field like this:
item1, item 2, item 3
to a linked field (i.e. the values item1, item 2 and item 3 are values in the primary field of the linked table). Is that right?
You can’t do this at the moment - at least not directly. Using the script block you can update a linked field but you need to know the record IDs of the records in the linked table. From the script docs the format is:
Where the record IDs (“rec…”) above are the record IDs from the linked table.
It is possible to do this in a script - I did have something similar to this that I was working on, so will try and put this out later today. Tbh, I’m sure someone else has already put out something like this on the community, but I can’t put my hand on it. Other members might be able to point to it in the meantime.
This script from @Sam_Cederwall is also along similar lines so you might be able to tweak this for your use case:
Your assumption is accurate on what I am trying to achieve. This is part of a project to successfully backlink between rows in the same table. At the moment I am using a script to conduct the backlink (works fine), but then I have to join two linked fields on the same row into a single field, which I’m using a concatenate formula to achieve, but I can’t do that on a linked field, hence the last step of trying to copy and paste via a script to a linked field. Perhaps I could use a script to join the two linked fields
instead?
Your multi-selects were probably created in a different way so the choices have different ids and/or names.
If you are sure that the target field contains all of the choices in the source field, you can map the original choices to make the array match the write format for a multi-select, using the name but not the id of the choice.
