Using filter changes other user's views
2356 2
Judy_Dang
My two colleagues and I are editing the same base. When I filter the records on my computer, their views get filtered also. How do collaborators use Airtable simultaneously without messing up others’ views?
Gabriele_Farei
I suggest to create to separate grid views within the base (one for each of you) so that you can work simultaneously.
Judy_Dang
Gabriele, thanks very much. Will give that a try.
