Conditional automation not recognizing fields?
Topic Labels: Automations
239 0
Alyssa_Buchthal
7 - App Architect
7 - App Architect
I’m trying to implement a conditional automation, but when I go to test, even though I know the input contains a specific string, the condition group for that string isn’t being met. I also have no option to manually change the input in the testing box as promised, screenshot below of that. Has anybody else run into issues with conditional automations like that? It looks like the input is empty but I re-tested the trigger right before this and I know the record should have matched the run condition for the group.
0 Replies 0
