Help - Automations fail
Topic Labels: Automations
493 1
Jean-H
I would like to set up and automation that "At 9 AM every Monday, Airtable will automatically send a Slack message to a user if a certain condition is met (e.g., "Task1" is set to "Pending Activation"). The Slack message will have an actionable button (e.g., "activated"), and when clicked, it will update a specific field " Task 1" in Airtable (e.g., changing "Pending Activation" to "Activation"). But the test result is negative and showed received invalid inputs.
DisraeliGears01
7 - App Architect
7 - App Architect
Because the list is producing multiple records, you need the Slack action to be in a repeating group for all items in the list.
