Jul 18, 2022 09:00 AM
I’m looking for help or advice on how to create automations on one of my created tabs.
Basically, I work with a company that rents furniture. Our rental term lengths range from 30-90 days (90% are 60-day terms). Is it possible to create 2 automations that do the following?
Let me know if this is possible to do
Jul 19, 2022 12:44 AM
Hi Brittany, yeah this is doable.
For this, I would first create a new field called Google Calendar ID
or some such
I’d then make an automation that would trigger if the record’s Project Installation Date
value was not empty AND the Google Calendar ID
was empty, and I would make the automation:
Google Calendar ID
field of the original record with the ID generated from the previous stepFor this, I would make two formula fields
2 weeks before end date
would be to calculate when the exact date of 2 weeks before the term ends with the DATETIME_ADD()
formulaSend email
would be to check whether the present date is equals to the value from the previous field with the formula `TODAY() = {2 weeks before end date}The field Send email
would be used as the automation trigger, and the action would be to email the client
Do note the following limitation outlined here
If we can’t send emails, then I’d set up the action to be to message me on Slack or make a calendar event for me to notify the client or something
Let me know if you’ve got any questions!
