Jul 25, 2024 11:44 AM
Hi there,
I am new to using automations and hopeful this is something I'm just overlooking. I'm having trouble with an automation for a "Shift Reminder" SMS.
Goal is:
1. At a Trigger time find records with a Start Date of "day after" trigger
2. Send SMS to associated cell numbers with each trigger to remind of shift
I have no issues if there is only one record returned. The SMS goes through without issue. If there is a second record returned the first record SMS goes through but the second record SMS is ignored.
Would be so appreciative of any help! Thanks!
Solved! Go to Solution.
Jul 25, 2024 07:01 PM
Hmm, those screenshots look fine and it seems like it should work without issues. Could you provide a screenshot of the "Find Records" action settings?
If you could DM me a read-only invite link to a duplicated copy of your base with some example data I could take a look at this for you!
