Power Automate webhook to trigger automation
Topic Labels: Automations
731 2
auekk2787
7 - App Architect
7 - App Architect
I'm trying to connect MS Power Automate to Airtable. A lot of info seems to be stale out there.
I have this flow, which parses data. I found this step HTTP Webhook. I'm hoping to make this a trigger for an Airtable automation. However, when I run the flow, it gives me a bad request error at this step.
Does anyone know if this is possible to set up like this?
I was missing a header and body. This works.
DJ_Montoya
Have you tried having your webhook set a field.  That field would be what triggered your automation.  That seems like a quick way to move past the blocker.
