Problem with airtable Team Plan
Topic Labels: Automations
399 2
HarshRane
I cannot use the " Run Script " function under the Automation Tab, even when the team's plan is activated. It's asking me to upgrade to a Business Plan. Please help
Dimitris_Goudis
10 - Mercury
10 - Mercury
@HarshRane your image shows a request to Team plan not to Business plan. Did you contact support?
18 - Pluto
18 - Pluto
Are you on a full paid team plan, or on a trial team plan? If you are on the trial, you may need to wait until after the trial period is over before being able to run automation scripts. If you need access to automation scripts before the trial is over, you should contact support and explain your situation.
Another possibility is that you have multiple workspaces and this particular base is in a free workspace.
