Mar 30, 2022 07:44 AM
Hello All,
Essentially, is there a way to set the column widths in a view other than clicking and dragging each separate one?
I have to change the width of something like 10 fields across 50 views, and I’d rather not have to click and drag 500 fields individually. Especially since they all should be a standard width.
I’ve looked around online and haven’t found anything - but if you know of a solution, you’d save me a lot of time.
Solved! Go to Solution.
Mar 30, 2022 08:24 AM
I have clients that would like this ability as well. I would submit this as a feature request to support@airtable.com.
Mar 30, 2022 10:43 AM
Thanks so much! It would be a great feature.
