Is there a way to create complex multiselect field?
855 2
rjcristy
I wanted my user records to have a field determining skills and proficiency for each skills
Say for example
Full Name | Language Proficiencies
Elsa | English - Beginner, Dutch - Mid-Level, Japanese - Fluent
How do I achieve that?
low-code-Rachel
There's a few options depending on what you're trying to accomplish. It ultimately comes down to what info you want to use to filter or automate.
One Long text field: You could keep the text "Beginner, Dutch - Mid-Level, Japanese - Fluent" in a long text field. You could then create filtered views that reduce the Language field down to text that contains "Dutch" or "Japanese - Fluent" etc. based on your interests.
One Multi-Select field: You could use one multi-select field with 3-4 variations of each language. Your options would include:
  • English - Beginner
  • English - Mid-Level
  • English - Advanced
  • English - Fluent
  • Dutch - Beginner
  • Dutch - Mid-Level
  • Dutch - Advanced
  • Dutch - Fluent
  • ... etc.
Multi Select field w/ details in long text field: You could have one multi select field that stores the language (Options: English, Dutch, Japanese, etc.) then keep details in an additional long text field (contents: "Beginner, Dutch - Mid-Level, Japanese - Fluent")
I don't recommend creating many different fields for different languages, because it becomes hard to organize/filter at that point.
If you want to talk anything through, you can schedule time w/ me here.
low-code-Rachel
  • English - Fluent
  • Dutch - Beginner
  • Dutch - Mid-Level
  • Dutch - Advanced
  • Dutch - Fluent
  • ... etc.
rjcristy
Just in any case someone encounters similar issue, I solved this using One Multi-Select field from @low-code-Rachel, with some application of scripting and schduled automation
So there are two tables: Language and Language Proficiency. Every interval time, the automation checks from Proficiency if there are records that doesn't exist that exists inside Language table, something like
if(!(profiencyRecords.indexOf((stackRecord + " - Junior") ) > -1))
  If it doesn't exist, records will be added.
