Nov 03, 2022 12:02 PM
I’ve tried to demonstrate what I’m looking for in this video: Loom | Free Screen & Video Recording Software | Loom
Nov 03, 2022 03:39 PM
Hi @Maddy_French and welcome!
It seems like your difficulty stems from trying to use the the “Action Items/Notes” field for two purposes at the same time:
I might suggest that you use the current field for only the second purpose and add another link field for the first purpose.
So from your Status table, you’d still have the “Action Item/Notes” column and now another link column perhaps named “Notes history.” In the Notes table, I would rename your “client” column to something like “Active Issue for” and then the new link column could be named “Client.”
With this solution:
You could consider adding an Airtable automation that would delete that link for you automatically when a Note’s status is set to Done. You could also have automation establish the “Active Issue for” link in the first place rather than having to manually link the client entry in both columns.
Nov 03, 2022 08:49 PM
Thanks so much for your help, Nathaniel! This helped me fix the stated problem and another related one in another base :grinning_face_with_big_eyes: You rock
