Need help with trimming
  • January 22, 2021
  • 100 views
I have a field for first name and last name where people routinely throw in an extra space after the name so that it will be "john " instead of “john”. I am unfamiliar with js but I would imagine there is an easy script that would trim that last " " off the first name. Help please!
David
  • January 22, 2021
Yep…
let trimmedName = name.trim();
  • January 22, 2021
So if the Name of the Field is First Name, what would I put under the automation script section. Sorry for the silliness of the question
  • January 22, 2021
Hi David,
There are no silly questions, especially in software development.
Ahhhh, that’s a very deep discussion and unlikely to remain a mystery answered without a full understanding of the table itself and any actions that occur before the script section.
Unless you acquire some essential understanding of developing in JavaScript, this thread could last well into the Spring. I recommend a quick introduction to Airtable scripting with this video.
  • January 22, 2021
Hi David,
Thanks for the intro - watching now. To answer your question, literally no actial will be happening other than a new entry being created in Airtable, which then needs the one field trimmed.
  • January 22, 2021
Take a look at this post and the code - it will help you understand what’s required to read fields and write them back changed.
