Dec 06, 2023 10:41 AM
Hi All
I am trying to connect to airtables through power bi and have the API setup with the key, base id and table id. however when i enter the details into Power Bi i get an "We couldn't authenticate with the credentials provided. Please try again." error. now sure why as i do have access to the airtable with the same power bi credentials.
Thanks
Jan 26, 2024 01:43 PM
was facing the same issue. just solved it on my end. chat gpt provided a different method than what was described in their documentation. hope this helps!
Open Power BI and Navigate to 'Get Data':
Choose the Web Connector:
Use the Advanced Option:
Enter the API URL:
Add Headers for Authentication:
Confirm and Connect:
Load and Transform Data:
