Hi @alato014 ,
To solve your problem, try using a conditional 'IF()' statement. This will follow the same format you have currently but will first check if there is a guest name. If there is a guest name, the formula will concatenate the invitee's first name, last name, and guest name. If there is no guest name, it will only concatenate the invitee's first and last name. Here is a breakdown:
Formula:
{Guest Name (from Relationship)},
Title & " " & {First Name} & " " & {Last Name} & " & " & {Guest Name (from Relationship)},
Explanation: The formula format is: IF({Field Name}, value_if_true, value_if_false).
The way this works for your example is:
- If({Guest Name (from Relationship)}, ...) checks if the {Guest Name (from Relationship)} field contains any value.
- If it does, the formula concatenates the title, first name, last name, "&", and the guest's name.
- If it doesn't, it only concatenates the title, first name, and last name.
Hope that helps. Goodluck with the wedding planning, and congrats!
