*Help* Formula for different hourly rate for multiple workers
  • May 26, 2022
  • 47 views
Bit of a tricky one for me, im looking for a formula for this situation with a multiple select box:
if ‘Jon’ selected =£18,
if ‘Carl’ selected =£20,
if ‘Jon’&‘Carl’ or ‘Carl&Jon’ selected £38
just a snippet of what im after, i have 7 opperatives on different rates, basically looking to then multiply by hours on site to get a final expenditure.
Any help i would be greateful
Forum|alt.badge.img+31
EDIT: Hey Aaron, here’s how you would accomplish this with a formula, but I do not think you should do this and recommend @Justin_Barrett’s suggestion below instead
We bundle everything into a single formula field that checks a multiple select field
e.g.
  AND(
    FIND('Jon', People),
    FIND('Carl', People)
  38,
     18,
      FIND('Carl', People),
      20
I do not recommend this as it would get super confusing after awhile; and adding / removing people would be a huge pain with modifying the formula
Edit: Also deleted my second suggestion that involved multiple formula fields as @Justin_Barrett’s solution is much much better
Welcome to the community, @Aaron_Preston! :grinning_face_with_big_eyes: Because you’ve got data that’s uniquely tied to each worker, I recommend creating a [Workers] table. Each worker would have a record in the table, and a {Rate} field would contain each worker’s unique rate.
With that set up, you link the records in your main table to as many workers as needed from the [Workers] table. To bring in their respective rates, add a rollup field. This would retrieve the value from the {Rate} field, with a SUM(values) aggregation formula adding it all together. No matter the order of the links, each worker’s unique rate would be added to the total, removing the need for complex formulas.
  • May 27, 2022
Thank you for the response! you can tell im new at this, ive realised over night that the plan i had for these feilds would not work in the grand scheme of thuings for what im trying to achieve due to the mathmatics.
Back to the drawing board i go!
Thank You
