Oct 03, 2022 07:11 AM
There seems to be an error in the SUM calculation of a list of my entries ( on multiple tabs also!). In the grid view, I click the “field name” to see the SUM of the added numbers but the total is always incorrect. I used a calculator to add the numbers up manuall and I get a differnet total.
It must be a simple error, but I have not been able to find the solution.
Please help because I’m trying to use Airtable for my business and these incorrect totals are causing a serious problem for my balance sheet.
Oct 03, 2022 07:31 AM
We can’t really help without seeing the data.
Oct 03, 2022 08:17 AM
How can I share this with you?
Oct 03, 2022 08:19 AM
Thanks for your reply Kamille. I have sent you a message in your inbox. Should we should we continue the conversation there?
