Help with IF Formula
  • September 19, 2018
  • 12 views
I am looking to write a formula to populate a field based on two separate fields using the IF AND statement.
This would be Field 1 = A and Field 2 = B then insert C into the formula field.
Is this possible?
Thank you.
Jason…
You have to join the conditions inside the IF with the AND function:
IF(AND(Condition1,Condition2),C)
