I need help on a date conversion formula
  • January 30, 2023
  • 57 views
Hello, I need help on an airtable formula. I have a date conversion formula: but I would like if the table is empty it says "Enter your birthday date" To avoid the error message please
my formula :
DATETIME_FORMAT(Dateofbirth, 'DD MMMM YYYY')
thank you in advance
Hi Philippe, see attached screen shots if you are more visual.
Based on your example, that would do it:
IF(Dateofbirth, DATETIME_FORMAT(Dateofbirth, 'DD MMMM YYYY'), "Enter your birthday date")
There might be other ways to do it. Hope it helps.
Cheers.
Matt
Ben_Young1
Forum|alt.badge.img+22
  • January 31, 2023
Hey @Philippe_Creve_ !
Here's a formula that accomplishes what you're looking for:
IF( {Date}, DATETIME_FORMAT( {Date}, "DD MMMM YYYY" ), "Please Enter Your Birthday" )
Feel free to pop your own preferred message into the formula if you'd like to change it around.
  • January 31, 2023
Cheers.
Matt
Hello Matt,
Thank you very much for your quick response, it helps me a lot.
  • January 31, 2023
Hello Ben,
It's awesome
