Feb 19, 2021 07:57 AM
Hey everyone,
Hoping somebody can help here.
I’m having trouble returning some info from a formula I have created.
I have a table to show the duration of certain tickets that are received for problems. I have a Date Raised field, Date Resolved field, and a Days Outstanding field.
I want the Days Outstanding to return the difference between Date Raised and Date Resolved when there is a value in the Date Resolved field, and I want it return the difference between Date Raised and TODAY() when the Date Resolved field is empty.
I’m currently using this formula:
IF({Date Resolved}!=BLANK(), DATETIME_DIFF({Date Resolved},{Date Raised}, ‘days’), DATETIME_DIFF(TODAY(),{Date Raised}, ‘days’))
It’s working fine when Date Resolved is populated, but returns NaN when it’s empty.
I have created another field just to check that the today-date resolved formula works and it’s returning exactly what I want, it just doesn’t work when it’s inside the IF formula
can anybody explain this and show me a solution?
Thanks in advance!
Solved! Go to Solution.
Feb 19, 2021 08:41 AM
Hey Alex, try taking out the !=BLANK() and just say IF({Date Resolved}, …
Feb 19, 2021 08:42 AM
Worked! Thanks my friend!
Feb 19, 2021 08:38 PM
As a side note, this could also be simplified a little by putting the IF()
function inside a single DATETIME_DIFF()
DATETIME_DIFF(IF({Date Resolved}, {Date Resolved}, TODAY()), {Date Raised}, 'days')
