Using an OR() Formula from two tables
  • October 4, 2023
  • 40 views
Soly
Forum|alt.badge.img+15
I have one formula field {Ball 1 ?} in the table A . The formula checks another table {Ball 1} via a linked record to see if it contains an attachment. If it does, the computed field writes "Yes", if it is empty, it writes "No". This part works fine.
I have another field (checkbox) named {Balloon 1} in the table A, that I want to add to the logic.
But when I add {Balloon 1} to the condition:
Meaning : If {Ball 1} OR {Balloon 1} is true, then writes "Yes" in {Ball 1 ? } and "No" if it is false.
I receive an error and it doesn't accept the formula.
Here is how I wrote it in the formula field {Ball 1 ?} :
IF( OR( {Ball 1},{Balloon 1} ), " Yes", " No", )
 How can I fix it ? Any advice ?
Best answer by Sho
Hello @Soly
This error is caused by the last comma.
IF( OR( {Ball 1},{Balloon 1} ), " Yes", " No" )
Forum|alt.badge.img+24
  • October 4, 2023
Hello @Soly
Soly
  • October 4, 2023
Hello @Soly
Thanks @Sho, I can't believe I missed that lol.
In the meantime, I went on to use nested IF's , like so :
IF( {Ball 1}, "Yes", IF({Balloon 1}, "Yes", "No" ) )
I'm glad I can now use the OR() you have corrected, as it was my first time experimenting with it.
Have a great day 🚀
