using f-string with filterByFormula
  • June 18, 2024
  • 49 views
i am using python-requests and trying to use f-string with filterByFormula here is a simple implementation:
hard coding the name worked:
url=f"https://api.airtable.com/v0/{base_id}/{table_name}/" headers={'Authorization': f'Bearer {api_key}', 'Content-Type': 'application/json'} query={"filterByFormula":"({full_name}="some name")"} response=requests.get(url, headers=headers, params=query) data=response.json()
 but when i tried to use f-string it didn't work. here is a a piece of code where the problem occurred:
url=f"https://api.airtable.com/v0/{base_id}/{table_name}/" headers={'Authorization': f'Bearer {api_key}', 'Content-Type': 'application/json'} employee_name="some name" query={"filterByFormula":f"{{full_name}}={employee_name}"} response=requests.get(url, headers=headers, params=query) data=response.json()
{'error': {'type': 'INVALID_FILTER_BY_FORMULA',
  'message': 'The formula for filtering records is invalid: Invalid formula. Please check your formula text.'}}
i wish somebody can help me with this
thanks
Best answer by wesam
I've found my mistake and i will post it here for reference for others:
the wrong code:
the right code (use single quotes for the '{employee_name}'):
query={"filterByFormula":f"{{full_name}}='{employee_name}'"}
the parameter placeholder must be in single quotes.
  • June 18, 2024
the wrong code:
