- Mark as New
- Bookmark
- Subscribe
- Subscribe to RSS Feed
- Permalink
‎May 30, 2023 11:46 AM
Hello, I recently noticed an issue with the column headers for list elements in interfaces. When you add a prefix field to the list, the column header for that prefix field is not visible. This is fine, except that this affects the alignment of the other column headers within the list. Specifically, the header for the second column that appears in the list (aka the first visible field that is not the prefix field), is aligned on the far left side of the list, over the prefix field instead of the field it's supposed to be referring to.
For example, if you want to display project information and your fields include Project Status, Project Title, and Project Staff, and you create a list element with Project Status as the prefix field, and Project Title and Project Staff as the visible fields, you will get a list that has three columns (one for each field), but only two column headers, with the "Project Status" header not visible, and "Project Title" aligned over the status column instead of the title column.
