Duplicate Interface into another Base
  • October 30, 2023
  • 416 views
Is it possible to duplicate an interface into another base? It's a lot of work to re-create, and would like to avoid if possible. If not, is this a feature airtable is currently working on?
  • October 31, 2023
This feature is not currently available.
Airtable rarely publishes what new features they are working on, but I doubt that they are working on this particular one. Duplicating an interface to another existing base would be very tricky to do because the corresponding tables and fields may not exist in the other base.
  • December 30, 2023
I have a 2023 database, now I would like to duplicate the entire base and its interface to another 2024 database. Is there any workaround or easier solution to duplicate the interface? Re-created the whole thing again is indeed a lot of work.
