Interface designer not working: "nothing published"
680 3
katiekazmi
Interface designer says "nothing is published" and does not give any action to continue on interface design. It only displays the error message.
katiekazmi
The solution is that I need creator access and I was on editor, thanks
3 Replies 3
Hey!
Did you click on the "Publish" button on the interface's "edit" mode?
To go back to the edit mode, you can always:
1. Open your actual data base.
2. Click on the Interfaces tab upper "margin", next to automations.
Once there you can click on the publish button as shown on image below.
I hope this helps. Otherwise, please provide some more context!
katiekazmi
Hello Mike and thank you for your assistance.
I am opening the actual data base, clicking the interfaces tab from the upper margin next to automations and it takes me to this blank screen that only says "nothing is published". There is no other buttons to press on this page and I have to go back to my data base.
katiekazmi
