Oct 18, 2022 05:31 AM
Hi there !
Here is my case, which seems pretty simple but I couldn’t find any solution for now :
I have a table called “Talents” and a table called “Positions”.
Both have the same fields as “Seniority”, “Department”, “Skills”, “Salary Range”, etc.
I want to be able to filter my Talents using the fields of a position. I basically want to get the Talents who match the position.
And I would like to create this Matching tool in the interface.
Any idea on how to do this ?
Thanks a lot !
Best,
Kevin
Oct 18, 2022 06:31 AM
Hmm, depending on your search criteria you could do this via a button in the interface?
You would have a record picker element where you could pick the position you want to find talent matches for, and have a button that would trigger an automation for you
That automation would find records in the Talents
table that matched the position’s criteria and then link said records to the Position
record
You can also hire me to just set it up for you too
Oct 18, 2022 09:07 AM
I would add formula to concatenate all 4 fields, link to a new table, copy-paste formula to link field, do the same for 2nd table, check new table for matches
Oct 19, 2022 01:33 AM
Hey Adam,
Thanks for your help !
I will try to set up an automation. But my goal is not to link the talents to the position in this case, it is to get a view of all talents matching the criterias. Maybe can I update the filters of a view via an automation, what do you think ?
Thanks again !
Cheers,
Kevin
Oct 20, 2022 09:42 PM
I don’t believe that’s possible I’m afraid
There’s a workaround that’s possible where we create a formula field that would find the matches for you, and you’d set your view filter against that? Would be a fair amount of work to set up and somewhat fragile though
Fair enough. It feels like the simplest way to get all the talents matching the position criteria though. What issues arise from having them linked like this?
