Using a Look up Field in an Interface
433 2
Laura_Vile
I have searched and can't find an answer to this one.
I am creating bar charts in one of my interfaces using a Look Up field, it won't return any data, it brings through the look up field lables in the X axis but no data comes through.  Am I doing something wrong or will Look Ups not work with charts within an interface?
Hm, could you provide some screenshots of your data and chart set up?
I seem to be able to display lookup values alright:
Link to base
Adi_Menayang
Hi Laura,
I think this might be a temporary problem, because I had an interface with charts using lookup fields that worked fine for a whole month, and just this week they weren't displaying properly. I explained more in my reply here (came to the Community to see if other people are having this issue and I've seen several posts about this! Hopefully Airtable notices and fixes it).
