Adding Zero to number while maintaing same amount of digits
  • February 3, 2018
  • 7 replies
  • 284 views
I’ve tried searching the forums, and while I’ve found posts similar to this, I haven’t quite found the formula that works for me.
I have a Job Number that is based off 3 other fields that I want to automatically generate when the other fields are filled manually.
Example
Job #: 72234-0001-001
Order #: 72234
Line Item: 1
Revision Level: 1
The order number typically does not need zeroes, but the line item fields and rev fields do, the zeros also need to adjust in the event there is lets say 10 line items, the center number still needs to be a 4 digits.
This seems doable, but I haven’t found the correct formula to do this. If anyone knows how to pull this off, thank you ahead of time!!
IF(LEN({Line Item})=1, “000”&{Line Item}, IF(LEN({Line Item})=2, “00”& {Line Item}, IF(LEN({Line Item})=3, 0&{Line Item}, {Line Item})))
IF(LEN({Revision Level})=1, “000”&{Revision Level}, IF(LEN({Revision Level})=2, “00”& {Revision Level}, {Revision Level}))
  • February 5, 2018
The rev level part didn’t work for some reason no matter how hard I tried, but the first IF statement worked great! Thank you so much Sam :slightly_smiling_face:
Forum|alt.badge.img+7
  • February 15, 2018
Is there a PAD function in airtable? I’m looking for a similar solution to an ID number.
Thanks,
Erica
  • February 15, 2018
AFAIK, you can’t force a field to a certain length by default. But there is a simpler formula that doesn’t require any IFs:
RIGHT("0000"&{Line Item},4)
RIGHT("000"&{Revision Level},3)
Note: Make sure the prepended string is at least the length of the desired final result, otherwise it’ll throw an error if the value field you want to pad is empty.
If you’re curious, the definition of the function is:
RIGHT(string, howMany)
Extract howMany characters from the end of the string.
  • February 15, 2018
Thanks so much Andy! That solved my problem perfectly and I’ll be using that formula in Client IDs, invoice numbers and several other places.
Erica
Thanks Andy. That’s a great solution :slightly_smiling_face:
Works in my slightly overcomplicated Client ID formula:
UPPER(LEFT(SUBSTITUTE({Customer Name}, " ", “”),4)) & RIGHT(“000”&{ID},3)
  • May 23, 2018
To left-pad {Number} with enough zeroes to make a string {Digit} digits long, use
REPT('0',{Digit}-LEN({Number}&''))&{Number}
(’LEN({Number}&'')’ returns the length of {Number} cast as a string.)
