Example Script Showcase - lots of them are missing
Topic Labels: Extensions
911 2
Rory_Kingan
Several of the community examples in the Script Showcase are just broken links, all pointing to https://community.airtable.com/t/weekend-scripting-block-challenge-and-1-000-prize/28074/5?u=kasra which doesn’t exist. Does anyone know where I can find them?
Showcase is here:
thanks,
Rory
Jason
Airtable Employee
Airtable Employee
Hi @Rory_Kingan, sorry about that, my mistake! I’ve restored those threads so all of the active links should be accessible.
That thread used to exist, but was removed over two weeks ago, maybe longer. I don’t know why. I lost posts on two different scripts that I discussed in that thread. You can find some of the scripts from that thread in the BuiltOnAir scripting library.
I haven’t been able to find a policy on what to do when a member has questions about a moderating decision.
Jason
Airtable Employee
Airtable Employee
