Hide Completed Tasks in Tables / Tabs within Project Planner
6504 10
Rachel_Gammon
I have lots of tabs for different locations of a tour plus a tab for tasks. In each location table I can see all my tasks associated with each record of the project. However once a task is completed I want to be able to hide it from the table view. Basically I want it to be clear at a glance where there is work to do in each location. I have worked out how to filter tasks by their status in the Task tab but seem to be unable to do so in the other tables.
When I click ‘Filter’ then ‘Tasks’ the options reduce down to only: Contains, Does not contain, Empty, Is not empty. When I type Completed nothing happens.
Any help would be much appreciated!
Thank you
10 Replies 10
Thanks for sharing! I know that what I’d said previously did work. I got laid off in April though, so haven’t worked with it since then and can’t really clarify because I don’t remember or have access to that table.
