Importing Data into a Multi Select field issues
  • November 4, 2021
  • 110 views
Hi There,
I’ve done an export from our website and want to import into Airtable. Most of the fields are fine but there is one field that I’d like to import as a Multi Select field but having issues.
A sample of the (anonymised) data looks like:
Apple~Chicken, Beef & Lamb~Rice~Pasta~Banana
Peach~Pear
Crisps, Chocolate and Sweets~Smoothie~Pineapple
Cheddar & Stilton~Pancakes
Pancakes~Apple~Peach
Crisps, Chocolate and Sweets~Pasta
For the above records I’d like them to appear as:
There are around 50 variables for the multi select field and the data itself is around 10,000 records so want to get the import right! And whilst we are looking at the API for the future, in the short term we will have to do multiple imports to keep the data up to date.
Advice welcome!
Thank you.
  • November 4, 2021
Hi Toni,
I have imported that type of field directly from a CSV export coming from a database just by using the CSV import app available in Airtable.
If you want to use this method, you may pay attention to the following:
  • CSV are comma separated, so there is a chance that you may end up in an error when exporting because a confusion between fields
  • To avoid that situation, try a CSV formatted like this example:
  • Include the headers in the first row (just for troubleshooting) and fill the data as
type, color, item
these are red items, red, “apple, cherry”
these are orange items, orange, “orange, peach, salmon”
these are blue items, blue, “smurf”
the CSV app will pick up the item enclosed between double quotes and put it correctly into a multiselect field in Airtable.
I hope that this helps
Good luck
  • February 24, 2023
Hi Toni,
type, color, item
Good luck
Can you append an example sheet, or explain more about:
type, color, item
Do you put ALL of that in the header? the original poster said they had like 50 different variables…
Thanks so much!!
– Kiki
