Old one way synced table does not turn to two way sync between bases
Topic Labels: Sync
404 1
burcbue
We have upgraded to Business account from Team. On Team plan I had set up one way synced tables, I have changed the configuration to allow creation of records from the target base. However, I still cant create new records on the synced table.
Do I need to sync the table again? I would like to avoid that because of the relations I have to renew in the target base.
atusr
8 - Airtable Astronomer
Did you solve it?
